Hey guys, I noticed that when trying to select multiple nodes you seem to need a minimum sized selection box, making it difficult to select the nodes you need in dense areas. Zooming in does not help, as the issue seems to relate directly to the actual area the selection box covers, not how much of the screen it covers.
Another question I had…I was wondering why ctrl-click is being used to insert nodes, when we already have the “i” key. Reason im asking is because it would be really useful to be able to deselect nodes using control, as with normal objects. I cannot control-box-deselect nodes either.
Otherwise, This feature has been super helpful. Gives me a lot more fine control
Also, When I have multiple nodes selected and I go to drag them, many times it will grab an anchor instead just drag that, forcing me to backtrack and re-select the nodes.
As a side question, When I am trying to grab a group of objects with the selection box, sometimes it will only grab objects when they are completely enclosed in the box (which I believe is the intended functionality) and other times it will grab an unwanted object even if I have the slightest overlap with that object (which makes it hard to grab certain objects in tight spaces). Am I missing something here or is that not supposed to happen?
