There is a small but annoying bug with variable text feature. When you have a file open with a CSV file populated and you open a file without one, it doesn’t clear the csv file field before opening the new file. Which makes it so when you save the once non-variable text file now has the same file as the previous file in the field. not a problem until you close and reopen the non-variable text file and it complains with a popup that it can’t find the file.
When editing 30 files and you now have references to one of those files using a csv, it’s extremely annoying to either have to clear the field and resave each file and make sure you didn’t reopen one containing an actual csv or the whole sequence starts again.
Thanks!
