Hi. I have a modifed 3D printer, so I have a Z axis.
I want add a command after first Z movement for wait to put the pieze to engrave (a m108 command ).
Any way to add this (or other) command?
Have you tried adding a start Gcode?
Its under Edit>Device Settings> then select the Gcode tab. You can add custom Start and End gcode here.
We do not have a generic / editable GCode generator at this time. You would need to save the GCode and modify it externally, then run it.
But I must change every time I change the height…
Ok.
Feature request
Ummm… Simple solution.
Add a custom gcode to move high Z (100mm for example), wait and now go to the material Z…
