Imported an image - (lbrn2, previously a png image created in photoshop)
Selected Tool Layer 1
Selected rectangle tool
Selected that portion of the image with the rectangle tool
Ctrl A to select both the rectangle and the image
Right clicked to see options. I did not see “apply mask to image”
I clicked on Tools tab and saw “apply mask to image” but it was grayed out.
I read in a similar topic “Have you selected one image and one other shape that is all closed vectors?” but I don’t know what that means (all closed vectors).
What am I doing wrong?
Appreciate any help.
Thank you,
Andy
Is the cut type “Line” for this rectangle? If it’s not, switch to Line.
Make sure you are only selecting 2 objects, the image and the mask, when you do this. You can see how many objects are selected at the bottom of the application.
Right click should show “Apply mask to image”. Alternatively you can get there from Tools->Apply mask to image.
Thanks berainlb,
I was able to make the mask. I selected the area with a rectangle, then while that was selected, I selected the entire image so at that point both were selected. While both were selected, I right clicked, which gave me the option of applying the mask.
Thank again,
Andy
Thanks jk,
Thank again,
Andy
