Arduino Nano laser not firing and Y axis not moving
Thanks to previous help, I discovered which board I have (Arduino Nano) and with that information I was able to do more research and used the Arduino IDE to upload GRBL into the library. I then opened LB and used the GRBL M3 option to set up my machine.
After all of that, my laser (which is not firing) will move along the X axis but not along the Y axis.
What am I missing?
Before the firmware update, my laser would fire but not move on either axis.
Probably you need to set $32=1 in your config settings. That and there might be another one to change. Go to the console in LightBurn, and type $$, then paste the results here.
Here is what shows up when I enter $$
$0=10 (step pulse, usec)
$1=25 (step idle delay, msec)
$2=0 (step port invert mask:00000000)
$3=0 (dir port invert mask:00000000)
$4=0 (step enable invert, bool)
$5=0 (limit pins invert, bool)
$6=0 (probe pin invert, bool)
$10=3 (status report mask:00000011)
$11=0.010 (junction deviation, mm)
$12=0.002 (arc tolerance, mm)
$13=0 (report inches, bool)
$20=0 (soft limits, bool)
$21=0 (hard limits, bool)
$22=0 (homing cycle, bool)
$23=0 (homing dir invert mask:00000000)
$24=25.000 (homing feed, mm/min)
$25=500.000 (homing seek, mm/min)
$26=250 (homing debounce, msec)
$27=1.000 (homing pull-off, mm)
$100=250.000 (x, step/mm)
$101=250.000 (y, step/mm)
$102=250.000 (z, step/mm)
$110=500.000 (x max rate, mm/min)
$111=500.000 (y max rate, mm/min)
$112=500.000 (z max rate, mm/min)
$120=10.000 (x accel, mm/sec^2)
$121=10.000 (y accel, mm/sec^2)
$122=10.000 (z accel, mm/sec^2)
$130=200.000 (x max travel, mm)
$131=200.000 (y max travel, mm)
$132=200.000 (z max travel, mm)
What version of GRBL are you running? Seems its missing some settings that are in the newer versions
I’m running GRBL 1.1
I did discover that I had a bad stepper motor driver which I replaced today. That solved my problem of my Y axis not moving. But now the direction of both X and Y axis are inverted and when I try to engrave an image, it goes super fast and doesn’t actually make any marks on the wood.
Here are my new settings after replacing the bad piece.
$0=10
$1=25
$2=0
$3=0
$4=0
$5=0
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=0
$23=0
$24=25.000
$25=500.000
$26=250
$27=1.000
$30=600
$31=1
$32=1
$100=250.000
$101=250.000
$102=250.000
$110=500.000
$111=500.000
$112=500.000
$120=10.000
$121=10.000
$122=10.000
$130=200.000
$131=200.000
$132=200.000
