Ok did a burn and the conduit that i have the wires from the laser and stepper motor got in the way and a small are didnt get lasered is there a way in light burn to start in that are to finish it? I will post a picture
Have you moved the piece? If it is still in exactly the same place on the work area you can use the node edit tool to break apart the vectors (closing them if necessary) in the area that did not finish change the layer color for the vectors you just separated and then only turn on the output for the new layer you just made. (be sure the new layer has the same speed/pwr settings as the original layer). If you have moved the piece then lining it back up perfectly is very difficult.
No i havent moved it i will try that
Thank you worked perfect!
