Argggggh! My mac problem is back
Spent hours trying to figure out why my Mac Mini would connect to my new Xtool D1 using Laserbox software but not connect using lightburn. I thought I fixed it by downloading and installing a mac driver. It worked great last night. I turn it on this morning and the same problem is back … lightburn will not connect to the Xtool D1 machine.
Its driving me crazy.
Can someone help get it connected?
Replaced the USB cable and problem has resolved itself.
Who would have thought a USB cable would work on one program and not on another.
While possible that the cable was the issue it’s possible that it was a red herring if this works with another program. Swapping the cable might have led you to doing things in a different order of operation.
Typically you’ll have better luck if you:
  1. plug laser into computer
  2. turn laser on
  3. turn LightBurn on
If you previously tried in a different order then LightBurn might default to a different com port. So change com port and possibly right-click Devices button.
You may want to try swapping USB cable back to see if the problem returns or if things continue to work.
