Hi Guys
I’m useing Lightburn 1.4,03
i use Lightburn 1.4.03
I make an array, but I cant select parts of it.
just the original square.
Circular array works Ok.
Anyone else having this problem?,
You have Create Virtual Array
turned on, which allows you to modify the array spacing and suchlike.
If you want separate copies, turn that switch off.
To fix the current array, select it, right-click, and select Flatten Array
Thanks Ed.
I found that out by playing around.
