Art library, add multiple times
I have a scrabble letter set in the art library. Each letter saved alone.
If somebody order 3pcs A, 4pcs B…I just add these from library. If I add it to the canvas, it put the designs to the top of each other. Is it any better solution than move the graphics by hand and then organize it horizontally and vertically?
Is it save layer cutting parameters too or just the design?
You could potentially drag and drop the design directly to the desired location. Not sure how much time it would save you.
If you were doing many objects of varying shape there might be some value to trying the Arrange->Nest Selected feature.
Art library only stores the design. Project files contain the cut settings.
Perfect,
Drag and drop is suitable for me instead of double click. Thanks.
