Artur laser master 2pro neje module
i have a question I have the laser master pro 2 and I have the NEJE 40 watt module
and it is not working can it be that the power adaptor is 24 v and 2ah and it must be 24v and 5ah
is that the problem
gerrit
Laser Master 2 Pro is a 24V system. NEJE, assuming it’s the A40640, is a 12V laser module.
You would be expected to step down the voltage or provide a separate 12V supply to power the laser.
Oké thanks I wil try it
can’t it be so that the laser is defect now
It’s possible. Don’t know if the laser module would be 24V tolerant.
Do you have an interface board with a test button on it that you can use to test it on its own?
I would not apply 24 volts to it.
The Neje 40 watt is rated at 12v @ 4 amps, which is a 48 watt input…
I have the 30 watt module, it is also 12v and the same 4 amp supply.
