Atezr L2 Autofocus does not appear to have power
Hey guys :v:, so I was asked to help out with an Atezr L2, and his autofocus does not appear to be getting power. His crosshairs are not on, when I try to home I get an error message, and when I did get the z axis to start moving it pushed all the way down onto our surface as if the probe was not reading, followed by an error message. I am able to move his laser on the x and y axis using the GRBL software and the machines touchpad, but can’t get it to work on Lightburn at all because it tries to home and fails and I get an error message, This was not the problem I was expecting to find when I showed up to help so I was not well prepared to deal with it. It’s certainly possible that he has more problems beyond this, but this was pretty much a non starter to get to any other issues. Oh, also, everything appears to be connected correctly so far as I can tell without disassembling the entire machine, nothing loose or disconnected in the wire harness.
Any suggestions on where to start? I have an Atezr v35 and I quite like it, but I’m starting to see why the company vanished from the face of the Earth. Thank you guys :pray:
Have you tried the Z axis options? maybe reverse Z…
