Homing has never has worked for the approx. 12 months of ownership of my A10 Pro. Decided to fix that if I could because I now need to use the feature. The following assumes you have completed everything within Lightburn correctly and homing still doesn’t work.
I recommended the A10 to a friend and his is working, he only bought his A10 a few weeks ago, so, is it firmware?
I downloaded the latest firmware and following the instructions within the download package installed the update. Tip: make sure that Lightburn isn’t running otherwise you will get an access denied error.
You will find the download on this page (well that’s it was when I created this topic):
Homing is now working correctly on my A10 Pro.
A warning: Having the latest firmware is nice but, as a general rule, if it ain’t broke don’t fix it! I only ever update firmware to fix a problem as things can go wrong, a power cut half way through an update (for example) will probably render the controller useless.
Hope this helps.
