AtomStack A40 won’t run job
I got a new A40 AtomStack. It fires, frames but will not run the job. S value is set to 1000
Post your .lbrn2 project file for us to check.
I’m not sure
You’re working in mm/Sec. on your diode laser you should be working in mm/min. You may be trying to run faster than your laser can go and that’s why it’s not outputting.
You change that in Settings(Gears Icon) Units and Grid.
Also, Parsec asked for your .lbrn2 file. That’s you project file. You can drag and drop it into the editor or use the upload button on the toolbar.
Please take actual screenshots, nit cell phone pics of your screen. The glare and moire make some images hard to see.
I’m sorry. I am not sure where to find the file you speak of.
It’s the file you’re working on. Your Lightburn project. When you click save in Lightburn, you put it somewhere on your computer. Navigate there and upload it. If you haven’t already saved the project you’re working on, you should.
You´re using default speed power and not creating a Material library you have to do some test with your laser/materials.
