Guten Morgen,
ich habe ein Problem mit meinem A5 pro.
Egal ob ich Bilder importiere oder direkt in Lightburn etwas zeichne - Alles wird ca. 20-25% größer gelasert/graviert.
Hat jemand eine Idee woran das liegen könnte?
Beste Grüße
Christian
Guten Morgen,
Beste Grüße
Christian
Probably you have not set up your machine correctly from the start. Has the machine ever worked properly. Which GRBL version have you chosen … ?
Try writing “A5” here in the search box up on the page … You might find a similar problem description and a solution there for it.
I have tried a new installation on my laptop. No settings changed. Only the x and y lengths for the A5 are specified. Everything else is the default settings that are found automatically.
I have the same problem with the LASERGRBL software.
A line that is 35mm long is lasered 45mm long…
Settings are:
$0=10
$1=25
$2=0
$3=0
$4=0
$5=1
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=0
$23=3
$24=300.000
$25=3000.000
$26=250.000
$27=1.000
$30=800.000
$31=0.000
$32=1
$37=1
$100=100.000
$101=100.000
$102=100.000
$103=100.000
$104=100.000
$105=100.000
$110=600.000
$111=600.000
$112=600.000
$113=1000.000
$114=1000.000
$115=1000.000
$120=600.000
$121=600.000
$122=600.000
$123=200.000
$124=200.000
$125=200.000
$130=400.000
$131=400.000
$132=200.000
$133=300.000
$134=300.000
$135=300.000
I have no Idea?!?
Have you had your laser connected to another computer before?, it sounds like you are moving to another computer.
If it has run before then you can just use the working setup file from the old computer.
…which grbl version are you using?
[quote=“cyberiss, post:3, topic:124534”]
$100=100.000
$101=100.000
…they should probably be 80, but that needs to be confirmed by a more experienced grbl man than me.
Where can i see, which grbl i’m using? As i wrote - i did not import any settings…?!?
$100=80.00
$101=80.00
will work!!
But these settings will not be saved after restart lightburn, right?
If I remember right, the changes from the console should be saved, you can just try it ;-).
I don’t have the opportunity right now to try machine settings for GRBL machines here with me, but assume you can change them through Lightburn. Again, a more competent GRBL user will surely be able to say good for it.
In your machine profile you will see which GRBL version has been selected
