Does anyone have sects for Atomstack A5 Pro + laser?
I am starting and I tried manual configuration with X 410 and y 400 origin front left, then I left home automatic, but when I turned on the limits were not correct and the cart slammed in all two directions beyond the limits. I switched off and placed on x max and y max manually, but again sliced up at the end of the race and then spurned.
Something is wrong.
What are sects?
Did you add limit switches? Don’t believe the A5 Pro comes with limit switches so should not be set to home. You should disable auto-home on startup. Normally you’d get an error message indicating that Homing is not enabled in GRBL configuration.
You would need to place at x and y min, not max. So front left. And again, disable “Auto-home on startup”.
