Atomstack Not Engraving on Metal
Hello, i am very new to having an engraver. I messed with it for a bit and was able to engrave on aluminum and metal cards but now it wont engrave on these. Wood is not a problem, what could i have done to have messed this up? I have a Atomstack P7 M30 if that helps, also i am not familiar with any of the softwares.
I believe this is a UV laser.?
Generally what makes or breaks it is the focus… Ensure you have focused properly.
These are multiple laser diodes and shock (mechanical) can cause internal alignment issues…
So far the only thing I can think of is the focus…
You haven’t modified any of the setting on the layer…?
Hey, where can i find the focus option and the layer settings?
You won’t get a lot out of your laser until you can find your way around the software driving it. I suggest you go to the Lightburn videos and watch a few. At least it will get you going in the right direction… Probably don’t need the QR code one…
Good luck
Thank you, ill check them out tonight and see if i can figure it out with the tutorials
