Atomstack Rotary Setup -
I watched the Lightburn YouTube video (Rotary engraving with the xTool D1 - YouTube). on setting up the rotary for the D1 and have a couple of questions.
  1. Does the roller diameter value change depending on the object you’re are engraving? For instance, a tumbler is bigger than the dowel rod in the example and I would space the rollers further apart.
  2. Is the Z axis used for Atomstack R1 rotary device too?
  3. What do you change depending on the diamater of the object you are engraving - just the object diameter? If so…
    3A. Do you leave mm per rotation and roller diamater to the default settings of 360mm and 17mm
