I am going to mount the Atomstack to a bench as I will be adding a Yaxis rails, Once I am affixed to the bench I would like the laser to start at the Yaxis 0 on the machine
ruler and the same with the Xaxis set to the 0.
I want to place two register boards one horizontal and one vertical, this makes sure my cut is square with my world.
Was there a question in there? This may help…
Mount the laser frame so it does not move. Use the laser to burn lines across the X and Y axis. That will be your guidelines for mounting the register boards.
Thank you very much question solved
