Atomstack X30 Pro Laser Module Issue
Having an issue with the laser module on the Atomstack X30 Pro. When i start the machine sometimes the laser fan doesn’t come on. Also when i try to cut the laser doesn’t fire. If i wiggle the wiring to the connector on the laser module that corrects both issues. Seems like either the connector on the cable or the socket on the laser module is flakey. Anyone experience this issue and how to correct.
More than likely the wires are not fitted correctly in the block on the cable and that is giving you a bad connection.
