Using LightBurn 0.9.11, importing AutoCAD 2007 DXF with mixed scanned text and scanned objects on same layer import the text at the incorrect position.
I have a DXF file that includes both text and objects. When imported, the objects import at the correct position relative to the project outline, but the text imports about off by about (5cm,-30cm).
The offset is immediately apparent in LightBurn after importing.
Note: The DXF is in inches; LightBurn is set to import in inches to match.
I can provide a DXF file that exhibits the problem.
