Automatische Suche funktioniert nicht
Hello, why isn’t my Atomstack AIC1 controller found in Lightburn? The port is set correctly, and I can also configure it manually. However, the automatic search doesn’t work.
Regards
Gerhart
The automatic device search function works fine enough, it just doesn’t find your machine. There are many new controllers on the market and if they meet certain standards they are mostly found by LB. If you can install your laser manually and everything works fine, then there is probably no problem. For example, my clone of a Ruida was not found at first but has always worked fine with LightBurn.
