Axe y et x sont inverse
Bonjour
Pon axe y et x sont inverse quel sont les formules à écrire pour les récupérer
Type $$ into Console Window and check here the output:
Your bio shows the S9 and S10 machines. Is it swapped on both machines?
sculpfun S10 w10
If the S9 is okay, then the issue is with the S10. Any possibility you swapped the connectors on the controller board?
Is the Swap X/Y Output switch turned on in the Basic Settings tab?
And the laser origin in Device Settings.
Si je comprends tout les paramètres sont changé???
No, only how they are linked.
Machine control is metric most of the time.
Some people prefer to use the same units, inch or metric, for both design and machine control. Turn Link on.
Some people [like myself] prefer to design with a mixture of both inches and metric, but always use metric for the machine control. Turn Link off.
