Barely burned image
Tried burning a tile using lightburn and ran into a problem. Norton White Tile method.
Everything seemed to burn correctly, but the burn did not go “deep” enough, it barely burned through the paint. When I cleaned off the paint, there was no image burned into the tile.
I have been using LaserGRBL, with speed of 900, power 75% and have had no problems. Burns have been good.
attached is a screengrab of my lightburn settings, should I be increasing the power for use in lightburn or check some other settings? I have Atomstack A5/20w.lb burn
