I’m watching through the tutorials on YouTube. The speaker keeps referring to cutting. How do you tell light burn to burn rather than cut? And vice versa?
Also, how do you use lightburn to burn images on multiple objects?
Obviously these are newby questions, so thanks for patience and for any links you can send.
need help would like to talk to some one on the phone first time user set up project frame it everything went good hit start the laser took off for the opposite corner from home didn’t firs just set up nex to the rail
So sorry to hear and hope all are on the mend and feeling better soon.
The post I shared above really is a good place to start. This lasing journey might reacquaint you with some familiar words, yet in a different context. The project I am sharing above should help.
Generally, in LightBurn, when wanting to just mark the surface or deeper - producing a cut all the way through, following the lines of your art, is known as a Line setting. Cut/Mark = Line. Setting a layer to Fill, will produce filled shapes, sweeping back and forth until the shape is produced. For producing pictures or images (bitmap raster), these settings are known as Image Mode options.
