Basic shapes are not closed
I found that some objects are not closed. Even in a preview, I see it. When I draw basic objects like Rectangle, circle I see some part of the object is missed. What could be wrong?
Are the objects actually not closed or is it that they are being shown as incomplete in Preview.
If it’s only the latter, check to see if you have Tabs/Bridges enabled in Cut Settings. If so, disable and that should remedy the issue.
thank you for your reply. Where are Cut Settings?
Double-click the Layer for the Cut Setting:
Will open up to this:
That helps! Thank you very much!!!
