With the Ruida controller, you can manually pulse the beam and specify the beams duration (e.g. 20ms). Is there a way in Lightburn to do the same thru software? I want to automate Russ’s beam mode test by creating a set of dots (points) and set a beam power and duration for each in a separate layer. Is that possible?
Sort of - if you created short lines, and used “dot mode” with a spacing value set longer than the line length, it would create a single dot at the start of each line, for the specified power and duration. That would do what you want.
