error:2
Numeric value format is not valid or missing an expected value.
ok
error:24
Two G-code commands that both require the use of the XYZ axis words were detected in the block.
error:1
G-code words consist of a letter and a value. Letter was not found.
error:2
error:24
error:1
error:2
error:24
error:1
error:2
error:24
ok
error:1
error:2
ok
ok
error:2
error:24
[AUTHOR: ORTUR]
[MODEL: Ortur Laser Master 2]
[OLF: 140]
[DATE:17:23:54 - Jan 4 2021]
[VER:1.1h.20190903:]
[OPT:VNZHI,99,254]
Target buffer size found
ok
Homing
These started showing up in the command window if I stop a burn or when the burn finishes. Seems to have started some time after the latest update.
They don’t seem to be causing issues on the burns that I know of…
Bugs in the software or settings?
Ideas?
