Been off for a while now setting are different
Ok here I go before I started Reno’s at my house I would use a test burn grid speed 700 to 1000 power 10 to 100
Now when I run it all of a sudden when I check the speed for a burn say 700 it tells me the speed is like 35.2 what’s going on ? Any help would be appreciated thanks in advance
Are both Lightburn and your laser in the same units?
Inches or mm?
With a laser diode, working in mm/min is the most common approach. If you inadvertently switched to inches per minute the conversion factor is 25.4 mm/inch.
If you’re seeing 35.2 inches / minute, multiply it by 25.4 mm / inch. Inches cancel and you’re left with mm/minute.
I get 894.08 mm/minute. Could the speed have been set for 900 mm/minute?
