@Blake is probably pretty close even without the methane gas being involved… it is explosive…
I have done something similar. You have it rather close if you are just getting some ‘stringy’ edge residue but it’s peeling off.
I load a ‘line’, usually the width of the material. Cut the material if necessary to lower the cost (multiple tests) and make it easier to manipulate the material for observation.
If I wish to engrave deep enough for magnets, I can run higher or lower power/speed set at the console and figure out what power/speed gives me the proper depth. I only need a line to see how deep it goes.
I think you are probably close to the ‘sweet spot’. What I mean is all machines vary the ‘speeds and feeds’ for the best results. It’s most obvious in a milling machine or other tool. Move too fast it ‘binds’ the tool, too slow it over heats the tool.
If you run 100mm/s at 50%, it should be the same amount of ‘heat’ as 200mm/s at 100%. If it cuts at 100mm/s @ 50% and it cuts at 150mm/s @ 60% there is some spot in the middle where the speed and the power result in the best cut, least amount of ‘burn’ and a more ‘clean’ cut.
I’ve had some mdf that cuts at 60% power, but at 68% power it cuts so clean it leaves no carbon residue. Wipe you finger over it and your finger is still clean…
You will probably have to fine tune either the speed, feed or both for best results. Laser power is usually associate with the ‘speed’ and feed is the how fast the material or head move past each other.
At that point, you need to load a square or something that has corners to figure out the best minimum speed. I assume a vector cut.
This is so important that I pay real money every year for a windows program that runs on the wifes computer so I can compute only speeds and feeds for a particular bit/material. Haven’t figure out how to do that with a laser beam…
I think there are too many variables…
I wish I could give you a pair of numbers and you’d be a happy camper for life…
You will notice how quick and easy this can be after you’ve done it 3k times… it’s a learned ‘art’ …
As far as it not following the line exactly, that is a different issue. They both need to be fixed but it’s unlikely that one cause is responsible for both. I’d look at them as separate issues.
Good luck
