# Best setting for laser etching on tempered glass
**URL:** <https://forum.lightburnsoftware.com/t/best-setting-for-laser-etching-on-tempered-glass/101349>\
**Category:** OS Specific\
**Created:** [May 28, 2023, 8:08pm UTC](https://forum.lightburnsoftware.com/t/best-setting-for-laser-etching-on-tempered-glass/101349 "2023-05-28T20:08:55Z")\
**Showing post:** 4
**Post date:** [May 29, 2023, 12:31am UTC](https://forum.lightburnsoftware.com/t/best-setting-for-laser-etching-on-tempered-glass/101349/4 "2023-05-29T00:31:36Z")
> [@Mhol](#):
> do you mean it should be a CO2
A visible light laser is not going to work on something you can see through. The materials must block/absorb the energy of the laser beam… if it just passes through, it can’t damage the material. That is why you are using the dark paper…
I’ve seen many people use tempera paint, black markers, various lubricants and many other things to change how the laser effects the material.
There is also the Norton White Tile method that molecularly bonds TiO2 to glass and other materials… Some of us use it with water and lase it. The NTM usually uses paint, that you have to get off after you lase it…
> [@New Method for White Tile Engraving: Norton White Tile Principal Component Method](https://forum.lightburnsoftware.com/t/new-method-for-white-tile-engraving-norton-white-tile-principal-component-method/38053):
> In this blog post I detail the method I developed to apply TiO2 to tile for laser engraving. It has the benefits of significantly reduced fumes, no dry time, consistent results, and easy cleanup by washing with water, while producing the same indelible results the Norton White Tile Method is known for.
@Bulldog does incredibly masterful work with this technique… lately he’s applied it to his new fiber laser…
> [@Norton White Tiles with JPT 60 watt MOPA](https://forum.lightburnsoftware.com/t/norton-white-tiles-with-jpt-60-watt-mopa/96353):
> NWT using JPT 60 watt MOPA 100 mm/sec 30% power 1000 Khz 200 ns 423 DPI
Good luck
_[View the full topic](https://forum.lightburnsoftware.com/t/best-setting-for-laser-etching-on-tempered-glass/101349)._
