Black-red laser calibration problem
Hello!
First of all, a big greeting to everyone on the forum and sorry for my English. This is my first post here. Of course, I have a problem.
I have a black-red Chinese laser 80W, which I was satisfied with and for now I don’t need anything better. I’m from Europe and I write measurements in millimeters :slight_smile:
Two days ago, during engraving, the power went out and since then my laser has not been working properly. Now I (probably) have calibration problems. When I want to cut a 10x10mm square, I actually end up with something 10x2mm. So the X axis is good, but the Y axis is quite inaccurate.
I tried to calibrate in the program RD Works File–>Vendor Settings–>Motor–>Y–>Step length–>Calculate step precision, but everything I tried did not give a good result.
Can something similar be set up in Lightburn. These are probably the same settings, but displayed in a slightly different way.
Perhaps the best solution would be to load the original settings into the controller. But unfortunately I don’t have them because the USB on which those files were - was stolen.
Therefore, as a first aid, I would like to ask if anyone has the correct settings for this kind of laser so I can try to solve the problem that way?
Thank you all and greetings from Croatia.
I’m not an expert but I’d look to see if the rotary got enabled first.
No, rotary is disabled, using switch on front side of machine.
Look in the controller settings too.
I thank everyone for the answers. The current situation is much better than yesterday. By trial and error I was able to get the laser working.
But now I have another problem.
The problem is the power output. Now the laser simply does not have enough power. Right now I can’t cut almost anything except paper, even when the power is at 100%.
I assume that some settings are involved, but I don’t know which ones. So, the laser works, but it seems that the power is at 15% and it can’t do more.
Suggestions?
The lenses are clean and adjusted, because I haven’t touched them.
Thank you!
How old is the machine? The laser tube doesn’t last forever.
Yesterday was just fine. Machine is five months old.
If anyone needs settings for a red-black Chinese laser 700x500 mm, you can find them here:
https://drive.google.com/drive/folders/1JQ8RnMgtqkf-Y4Q0H55ffbcZLlXWYutd?usp=sharing
