Black specs close to edge of image
working with hardwoods On a simple image i get specs close to burn lines but not in open space
Without seeing your design or the burn I’m going to guess that you’re burning an image. And I’m going to guess that the specs you’re referring to are from noise in the image, probably from compression artifacts near the lines. Check preview and zoom in to see if you can see these.
Also, if the specs are repeatable on multiple burns they’re almost certainly in the design itself.
If that’s not right, can you post your design preferably as a .lbrn file or else a screenshot and a sample photo of the specs you’re talking about?
Thanks. Probably the image. Downloaded off net
