Once in a while I get an engraving that the laser simply shuts off for a time causing a blank section in engrave. I done two of the same image to see if it happened in same portion, did not. It was later
Any bright ideas what causes that, please let me know
Assuming the Preview always correctly shows the missing parts …
If the machine is connected by USB, then always start by suspecting USB communication glitches that knock out parts of the commands going to the laser:
If it’s the CO₂ laser in your profile, it may be a failing HV power supply.
If it’s a diode laser, it can be:
A failing wire in the cable to the laser head
The laser head shutting down due to overheating
The power supply browning out
More details will help us peer over your shoulder …
