I discovered this while trying to use the array function and thought that I was having a problem with that but in tracking back through my steps I discovered it was the Boolean that was causing my problem. Here are the steps:
Create hexagon with a height of 33mm
Create hexagon with a height of 20mm
Center the two hexes and weld
Create rectangle with a height of 4.5mm and a width of 3mm
Center rectangle with the top edge in line with the bottom edge of the inner hex
Perform a Boolean Difference to subtract the rectangle from the hex shape
At this point everything appears fine but if you measure the outer faces of the hexagon you will note that the sizes are no longer uniform. They should each be 19.05mm. But on this shape they now vary between 19.05 and 19.06.
This is not the intended behavior, is it? Did I screw up the operation somehow?
Okay, now that you ask the question I see that if I weld the rectangle to the inner hex before grouping the items I’m going to avoid the issue. Thanks.
Show us what you want to produce, and we may have some suggested workflows to help achieve your goal. With LightBurn, there are usually a few ways to get to where you would like to go.
