Good evening everybody I’m new in the forum, I tried to use search button but with no satisfying result…
In lightburn I have image borders that are visible more burned than other image points, what could it be? I use a 7w grbl diode ( old laseraxe frame) and an eleksmaker a3 stock and the result don’t change… Help me please
Hi Perri, It’s hard to take a stand on your issue without seeing an example.
In addition, you also need to state what kind of material and with what settings you have the bad result. Come with it and we will try to help you.
Solved using overscanning, thanks!
