I downloaded a pattern from Creative Fabrica. I had been working on the laser with some other patterns earlier today. When I sent this new pattern to the laser it gave a boundary error, which in my limited understanding means it is too close to the Edge ….so I moved the pattern over as you can see in the image. But I still get a boundary error, looking closely at the image I see that the very top and very bottom are not covered by the moves(circled on the photo). I tried a number of things to bring top and bottom into the Traverse Moves view but do not seem to be able. I am not sure if these are what is causing the boundary error, but it certainly seems to be far enough away from the edge? Has anyone else seen this?
What ‘Start From’ mode are you in? If you’re using ‘User Origin’ or ‘Current Position’ the position of the artwork within LightBurn doesn’t matter.
I believe I have figured out why I was getting a boundary error although now it has introduced an error I must find the cause of. After updating to 2.1.02 it appears my camera is way off. I use the camera to do my layout in almost every project I do. It took me awhile but I finally got to the point of putting the owl far enough to the right on the camera view that the job would run. What I got was completely unexpected! My owl in the camera was on the left of my board, when the job ran it was so far to the right, I suspect that is why it was giving me the boundary error. I am using a Noval Plus 24 from Thunder Laser and have not had to adjust the camera since I purchased the laser but this new update said I was running an older version of the camera software and asked if it should be updated to which I agreed (that is why we install updates). For now I can position stuff by using the Frame Tool so I can see where it will end up, but would love to get my camera working properly. Has anyone else seen this? While I hesitate to ask if I need to do an alignment (the camera through the last several updates has been SPOT ON) - do we think that would help?
