Brand New Master Laser 2 Can not get it going in Linux
I am running Ubuntu Studio 18.04. I just finished building my Ortur Laser Master 2. I hooked it up. I plugged the USB into the laser and computer, then while the adapter was not plugged into the wall yet, I attached it to the laser and the adapter lit up green. I then plugged the adapter into the wall. I started light burn and tried to find the laser and it could not find it. I then tried to manually install the laser and after going through all the prompts I am still not getting anything.
Did you add the user to the dialout group in Linux, so it can use the ports?
https://lightburnsoftware.github.io/NewDocs/Installation.html#linux-installation
Ok so I did that and the laser homed itself when I opened up lightburn which is the first time that has happened. Thank you.
familiarizing myself with the console and I am able to put coordinates in manually and it is moving to those points. Thank you again.
