Break up a Job into Smaller Parts
Just a thought. Friend of mine had a job that was going to take 17 hours to burn. This is what I came up with. I’m sure there’s other ways of doing this so be nice. This is not Print & Cut
Instructions in file Below. Change extension from TXT to PDF
Quick Trick to Break up a Job into Smaller Parts.txt (329.9 KB)
Thanks for sharing. Some minor remarks to enhance it: :slight_smile:
  • I’d use cut shapes function instead of boolean. Booleans only work with closed shapes. If you have open shapes / lines, this method won’t work
  • It seems you manually moved the “cut boxes” to the center line. Just hold ALT while dragging and it will snap to the center line.
  • Personally, I’d put both / all parts still in one file, that’s easier to handle :slight_smile: But that’s just my habit :slight_smile:
