I’m using the newest LB version on 2 windows laptops (both different screen resolution) when I set up LB on one laptop with the lowest screen resolution, export prefs and copy it on the other with a higher screen resolution the cut (colour) palette is in the wrong place a third from the bottom from the screen and I can’t move it.
Screenshot of the win10 laptop (with higher screen resolution) after copying over the lightburn prefs from the laptop with lower screen resolution, the cut palette can’t be moved, turning off, on, and restart of lightburn does not help:
