Bug - Shape properties corner radius
Hi team,
Just found some unexpected behaviour with radiusing corners of multiple shapes, in the Shape Properties window.
With two rectangles selected (of different dimensions), changing the corner radius sets the size of both shapes to zero, instead of just modifying the corner radius. I assume this is due to the ‘width’ and ‘height’ fields in the Shape Properties window (showing ‘multi’) being modified at the same time as the corner radius is set.
I have never seen that before. I’ll log this as a bug - thank you for reporting.
No trouble! It doesn’t occur when the shapes are the same dimensions as each other.
I’ve fixed this for the next update.
