Bug ? Unwanted Y axis movement with rotary connected to Z axis
Hi,
I have a rotary connected to the Z axis.
At the end of the job there is always a unwanted movement in the Y axis.
Here is a sample G-Code, where you can see the G-Code with the Y movement at the last line:
; LightBurn 1.7.00-RC-15 @ b993359
; GRBL device profile, current position
; Bounds: X0 Y-0.84 to X0 Y0.84
G00 G17 G40 G21 G54
G91
M4
; Cut @ 6000 mm/min, 20% power
M8
G0 X0Z0.829
; Layer C00
G1 Z-1.658S200F6000
M9
G1 S0
M5
; return to starting pos
G0 X0Y0.829
I think this should Z in the last G command instead of Y.
Y should not have any movement commands at all.
If have also tested it with A axis - same problem.
In the last line of code there is always a Y axis movement.
Another problem:
I have automatic home actived at startup.
While the rotary mode is active there still a home procedure at start up - I think this is also not quite correct.
My maschine is like a 3D printer with a moving bed in Y axis. So at startup my rotary is always moving through the machineā€¦
Regards,
Ingo
Hi,
with the lastest update the problem with the unwanted Y movement at the end of the job is fixed - thanks. :grinning:
Still a smaller issue is the automatic homing at startup and the movement to a user defined end position in rotary mode.
My suggesting is just to ignore this setting while rotary mode is active.
