Burning complete frame (betwn shapes) shapes
Hello, I am using foxalian mastur 20watt laser. before upgrade i was not having any issues, now with 1.4 upgrade its burning teh hole frame not just the image. i was doing a gray scall test and it did the hole image. i have posted the $$ below… i also confirm S value is set to the same has $30. i have looked at other posted and still no help
$0=10
$1=255
$2=0
$3=0
$4=0
$5=0
$6=0
$10=3
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=0
$23=3
$24=25.000
$25=1000.000
$26=250
$27=1.000
$30=1000
$31=0
$32=1
$100=80.000
$101=80.000
$102=801.670
$110=2000.000
$111=2000.000
$112=1200.000
$120=300.000
$121=300.000
$122=30.000
$130=400.000
$131=380.000
$132=55.000
It’s most likely either one of the two:
  1. the image is not true white or has noise that’s not white or transparent.
  2. your minimum power value for the grayscale layer is non-zero
The quality of the burn itself looks off so there may be something else going on at the same time.
There’s also the possibility of a hardware failure but I’d suggest ruling out any setting issues.
