Darren, my $$ settings are identical to yours, so let’s look at your LightBurn settings.
Try making a simple little sample project and submit here. (the .lbrn itself)
Hi, Heres the file I started to use fill with and had the issues. I am using the Grbl-M3 profile as the standard Grbl one was burning the “non burning” transfer moves. Tried the $32=1 command in the console but that didn’t solve it so moved to the M3 driver which largely solved that issue and gave me this one.
Heres a couple of pics of a test file I’m using, the blue line is a 10% fill which is resulting in the photo below…So the laser on in the movements.
Got it sussed! I em ailed Awesometech and after a couple of days they came back with the driver must be GRBL STM and that I must check the $$ to follow the instructions of “laser stuck on” on Mini Gerbil debugging – Laser operation – AwesomeTech also to check no cables had come loose…I checked the PWM cable was loose I secured it and tested…ALL PERFECT!
