Burns 3/4 of an inch to the right of the framing
I have been using LB successfully for a few months. The in Dec just a few days before Christmas I wanted to burn some last minute things. There was an update, which I downloaded. After that everything burns 3/4 of an inch, approximately, to the right of the framing. I have uploaded updates since then but it is still doing the same thing. How do I stop this from happening?
Are you using your cross hair as a reference frame or the actual laser?
COuld you share a print screen of edit > Device settings menu?
Yes I am using the crosshairs and frame out everything. Then it burns to the right of that. I have never had this problem until Dec
any chance on edit - device settings your crosshair offset is not correctly set?
that should be enabled
Thank you so much for your help! I really appreciate it.
did that fixed it? if so mark as Solution
Might help someone else
I will check it and mark it if it does. I am running late for an appointment now. If it doesn’t I will be back in here tomorrow night :joy:
That worked. Thank you so much for your help!
