Hello. My laser frequently goes “Busy” in LB. Happens a lot after a burn. I have to disconnect the usb cable and wait till “Disconnected” displays. Then reconnect.
Atomstack 5W. I have latest version of LB. Any help to solve this would be much appreciated. Happy Holidays
Is it hitting the limit switch all the way?
I don’t have limit switches. Nothing happens but a busy indication.
In my experience, this is usually happens with bad USB connections / electrical interference. Try another (high-quality) USB cord, another USB port and remove electrical disturbances and check again.
Thanx. I will try this. I’m using a MacBook. Hope that isn’t the problem.
A newer MacBook? Try a different USB hub or if you didn’t use one yet, try one.
Not a newer MacBook. New to me. Reconditioned 2019. I7. Don’t have USB hub. What will that do?
Sometimes, they clear out USB connection issues It’s just something you could try, to make sure the USB port is not the issue in itself.
