I recently moved my limit switch after upgrading my diode laser. My burn area has now changed. Is there a way of running the laser for it to calculate your new area for you? I had a 400x400mm previously, but no clue what it is now.
No. This is something you’ll need to configure.
It likely doesn’t have a different work area. It probably just doesn’t know where your origin should be.
Some base questions.
- What laser is this for?
- Where were the limit switches initially? Where did you move them to?
- What configuration changes have you made to account for this?
- Can you run a homing cycle and then run the commands in Console. Return results here:
$I
- Can you take a screenshot of Device Settings?
Ortur LM2 Pro - Upgraded with a Neje A40640
Front Left corner, had to move it forward about 5-7mm as the new module is bigger.
$I
[ORIGIN: China]
[PRODUCER: ORTUR]
[AUTHOR: ORTUR]
[MODEL: Ortur Laser Master 2 Pro S2]
[OLF: 187]
[OLH: OLM_ESP_PRO_V1.2]
[SN: 375DBFC21E70E8EE4A2F853BFB8A1CE9]
[OLM:GENERAL]
[DATE:17:26:04 - Dec 15 2021]
[VER:1.1f(ESP32).20210403:]
[OPT:VNMZHSL,35,7680,3]
Target buffer size found
ok
$0=5.0
$1=100
$2=0
$3=6
$4=7
$5=7
$6=1
$10=2047
$11=0.050
$12=0.002
$13=0
$14=6
$15=0
$16=1
$17=4
$18=0
$19=0
$20=1
$21=1
$22=1
$23=7
$24=600.000
$25=3000.000
$26=100
$27=3.000
$28=0.100
$29=0.0
$30=1000.
$31=0.
$32=1
$33=1000.000
$34=0.000
$35=0.000
$36=100.000
$37=0
$39=1
$40=1
$41=0
$42=1
$43=1
$44=3
$45=0
$46=0
$56=1.000
$57=1800.000
$58=395.000
$59=6000.000
$60=0
$61=0
$62=0
$63=3
$64=1
$65=0
$100=80.000
$101=80.000
$102=2124.000
$110=10200.000
$111=10200.000
$112=600.000
$120=2200.000
$121=1800.000
$122=200.000
$130=400.000
$131=400.000
$132=100.000
$259=0
$260=70
$261=0
$262=400
$263=30
$264=0
$265=50
$266=100
$267=0
$268=0
$269=0
$270=5120
ok
[G54:0.000,0.000,0.000]
[G55:0.000,0.000,0.000]
[G56:0.000,0.000,0.000]
[G57:0.000,0.000,0.000]
[G58:0.000,0.000,0.000]
[G59:0.000,0.000,0.000]
[G59.1:0.000,0.000,0.000]
[G59.2:0.000,0.000,0.000]
[G59.3:0.000,0.000,0.000]
[G28:0.000,0.000,0.000]
[G30:0.000,0.000,0.000]
[G59.6:0.000,0.000,0.000]
[G92:0.000,0.000,0.000]
[HOME:0.000,0.000,0.000:7]
[TLO:0.000]
[PRB:0.000,0.000,0.000:0]
ok
<Idle|MPos:0.000,0.000,0.000|Bf:35,7679|FS:0,0|Pn:P|CL:0,100|PS:2,1|ER:0,0|VA:23963,0|Ov:100,100,100|A:S|H:1,7>
ok
ok
Ah… okay. I misunderstood what you meant when you said you moved the limit switch. I thought you meant you relocated the homing location.
To accommodate this you’ll need to shorten your Y max travel. If you take off 7 mm then:
$131=393.000
First switch your units to mm in LightBurn then go to Device Settings and make the same change for your Y axis, 393 mm.
