Caliberation problems
I have the Ortur Pro Master 2 with the LU2-4-24volt laser, I make a 4x4 box but when I frame it frames 4x6" area what am I missing
You need to calibrate your axes, you can get help from Lightburn:
edit → machine settings → calibrate Axis
Are you willing to share your file?
I’m wondering if there’s something outside the 4"x4" box side.
https://lightburnsoftware.github.io/NewDocs/LaserWindow.html
Thanks I will give it a try tonight when I get home from work.
Thanks for the link I will check it out tonight.
I got it everyone thanks I had the “enable Rotary” checked, under the rotary list happy happy happy
