Trying to install LB camera. Not sure if this a problem with C3D board or Laser itself. Never run in this problem during regular cutting. Camera calibration was easy. Thanks to the video. But laser do not want to cut allignment pattern. Tried multiple times, and every time it is gets out of sync. Thanks.
It won’t be the file itself, but likely your acceleration or speed settings. Either you are trying to cut too fast, and it’s losing steps, or the acceleration in the config.txt file on the SD card is too high. I would start by lowering the acceleration value by about 20% and see if that helps.
