Just wondering if there’s any way to save, and edit the camera alignment wizard image to output to the laser. I have a ruida 6442 controller with laser 1 burnt out, so when I send the pattern to the laser, nothing gets cut, or engraved. I have tried changing my machine settings to disable laser 1, but the issue still persists after the change.
Technically any set of targets would work - The center points are in a 180mm square, centered in your workspace, scaled by whatever your scale factor is.
