Camera Alignment Wizard Problems
I noticed my camera alignment was out a bit and thought I would carry out alignment, as this seems necessary from time to time. When burning my test pattern, I have been using 195%, as this fills my 400 x 400 area on my Ortur Master 2 Pro quite well and should give greater accuracy.
However, on this occasion there is a problem in that the wizard cannot see all 4 corner targets unless the scale is reduced to say 150%, but the engraver can print them and the camera can see them. Please refer to the attached screenshot of the wizard. In the smaller left hand window, all 4 targets are shown, but in the larger right hand window, only the bottom two targets are shown. If I take the next sept, to pinpoint each target where you can zoom and pan the display, I’m not able to see the top two targets, so it’s not possible to proceed. I’ve carried out camera calibration of my 120 deg camera several times. I’ve had to use the “Standard” option as I get some very high and erratic readings if I try and use “Fisheye”. I discovered the problem with V1.5.02, but it’s still there if I load V 1.4.03.
In summary, I don’t know what’s changed and is preventing the wizard working as it used to?
